It almost sounds like a miss. It could be a dead for a couple of fuel injectors going out. You can do an easy check by disconnecting the coil to the cylinders one at a time and seeing if there is any change in the running condition of the car. If you unplug the coil and there is no change in the idle condition then you would have a possible injector or coil going bad on that particular cylinder. Just a thought though.
